Provide technical support information on the switch configuration by collecting the outputs of "show tech-support", "show ip nat", "show ip nat vlan" and "show ip nat rule" commands. Also, check the scalability limit and compare this with the current configuration.
Provide technical support information on the switch configuration. Also, check the scalability limit and compare this with the current configuration.
Critical
Argument %arg% has an invalid value %val%
| Name | Type |
| arg | String |
| val | uInt32 |
